Unconfigures a specified banner from CLI screens.
after-login | Specifies the banner that is displayed after login. |
before-login | Specifies the banner that is displayed before login. |
N/A.
CLI session before login.
CLI session after login.
If no optional parameters are specified, all configured banners are erased. To delete a specific banner, the before-login or after-login keyword must be used.
Banners can also be cleared by configuring a banner with only a <ret> or \n character.
The following command clears the after-login banner, Welcome to the switch:
unconfigure banner after-login [Return]
This command was first available in ExtremeXOS 12.5.
